300 Disk Brake Removal
Posted by sgill on April 05, 2010 at 10:27:45 from (198.151.13.7):
I have a Farmall 300 that will barely stop and want to take the brakes off and send them to OEM for their disk brake service. I have the Operators Manual but it doesn't provide details on how to remove the brake assembly. Removing the 5 bolts that hold each brake housing on looks pretty easy but can anyone give me details on the best way to disconnect/remove the brake operating rod linkage? If you loosen up the jam nuts, can it be screwed out - or should you loosen the brake housing and try to disconnect the yoke from the expander? Or how should it be done? Thanks.
