Posted by Kevin Brooks on April 05, 2010 at 12:33:37 from (129.42.208.179):
Have an "51 M with partially rebuilt carb: new needle/seat cage and gasket, new float bowl gasket. Float level measured 1 5/16" per manual. Finding gas leaking out choke lever shaft after increasing engine speed control. What is likely causing the leak. Also, main fuel/air mixture screw currently set at 3 turns out. Not yet tuned for full throttle. Would leak disappear once tuned? Tractor head listed as 6336 for kerosene and carburetor has numbers matching those for kerosene. However, I only run gas.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
