Re: swap 560 engine?
Posted by ih560 on April 05, 2010 at 19:43:10 from (67.131.50.233):
In Reply to: swap 560 engine? posted by gregk on April 04, 2010 at 08:02:25:
I have seen some very nice 560s for close to or less than $3,000 and required no work to make it function. Swapping engines isn't that hard but it is still a lot of work without some good help. I would rather take $3000 and put it into 1 nice tractor than 2 half good tractors. No offense, but I have been in these situations before where you are told one thing and then when you get everything together, you find more worries.
