Posted by RJV on April 05, 2010 at 21:12:25 from (75.187.154.242):
One of the bolt holes in my lower unit that holds the drawbar on is stripped out. these holes look tappered being larger on the inside and narrowing down as the bolt is threaded in. Do they take special studs or bolts? If tappered, would you tap it with a pipe thread? What is the correct way to fix this problem? For now, I just have a smaller bolt all the way through with a nut on the end. I havent tried getting a longer bolt yet, that will be the next thing I try.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
