Re: mounted plow for an H
Posted by CNKS on April 06, 2010 at 14:48:50 from (216.144.104.128):
In Reply to: mounted plow for an H posted by 36 A on April 06, 2010 at 13:02:29:
I don't know if IH made a mounted moldboard for the H. There is a 2 or 3 disk semimount plow for the H and M. I plowed many acres in the 50's with the 3 disk HM 150 on an H. It pulls from a bracket under the clutch housing. The rest bolts to the axles and is lifted by two cylinders attached to the arms that fit in the triangular bottom of the belly pump. It has a cast or forged steel wheel on the back that turns with a rod running to the front wheels. Turns fairly short to the left, will make wide right turns. Not actually a plow but IH also made a 3 row middlebuster, two in front and one in back.
