Re: IIH 436 Injector Leak
Posted by Owen Aaland on April 06, 2010 at 21:11:07 from (207.13.114.72):
In Reply to: IIH 436 Injector Leak posted by James22 on April 06, 2010 at 18:55:54:
If the injector is leaking internally and not from the external fittings there are no seals to replace to correct the problem. The surface finish between the nozzle assembly, body, and spacer all have to have a smooth enough finish that they will not leak under the nearly 4000 PSI the injectors operate.
If it is leaking antifreeze from around the injector then you will need to replace the nozzle in the head.
