Re: super c rear housing pulley help identify
Posted by markus54 on April 07, 2010 at 05:40:08 from (72.241.225.108):
In Reply to: Re: super c rear housing pulley help identify posted by Harold Hubbard on April 07, 2010 at 05:18:45:
I do not see a pulley being able to grind that much away....the pulley would be destroyed long before...and it would take several pulley"s to do that...i thank you for the reply and take it into consideration..if if was because of that rubbing..he must have changed it several times ...and i would think that he would have just moved it back a little on the shaft after buying the second pulley...but maybe the pulley has a hard time keeping tight ???I don"t know as i have never used one for a long time....
