Re: Type of oil for Lift All in an M
Posted by dhermesc on April 07, 2010 at 07:25:23 from (24.248.193.103):
In Reply to: Type of oil for Lift All in an M posted by Carl Grover on April 07, 2010 at 06:46:15:
It used to be non-detergent but any 30W will probably work now. The antifoaming agents used in current detergentated oils makes it a non-issue.
The same issue has also been resolved in "splash lube" small engines. Until the mid 1980s or so you had to use non-detergent oil due to foaming, now its not an issue and no manufacturer will even warranty their engine if you use non-detergent oil.
