Re: Oil for Lift All M again!
Posted by Andy Martin on April 07, 2010 at 08:04:55 from (199.197.2.156):
In Reply to: Oil for Lift All M again! posted by Carl Grover on April 07, 2010 at 07:59:24:
Hydraulic oil is OK, the heavier the better if you want to put out much pressure. HyTran is recommended but it is very thin and expensive. the one tractor I use on borrowed implements has hydraulic fluid to keep from contaminating the other guy's system with motor oil.
