Re: 806 hydraulic pump
Posted by bc on April 07, 2010 at 09:26:34 from (65.66.85.240):
In Reply to: 806 hydraulic pump posted by bjd49 on April 07, 2010 at 08:38:49:
A 17 should do ok with the present filter but if it cavitates at all, then think about a bigger filter and/or keeping them and screen clean. My 2606 has a 17 with the standard filter. It also has a canister filter on the loader as well.
What is it doing that you think the pump is bad, when did that happen, and how has it been doing over the past few years? Could be something else like a little crud blocking open a pressure relief valve. I hate to see someone spend big bucks for a pump and that not fix your problems.
