Yes, it will work. You will run the supply to the rod end of the the two way cylinder and when you supply fluid to the rod end the cylinder will retract compressing the spring if the spring is installed over the rod. When pressure is removed the spring will extend the rod from the cylinder. You will have to put a vent fitting on the clevis end or piston end of the cylinder so that you do not trap air on the piston end.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
