Re: Hydraulic cylinder question
Posted by IH fan on April 07, 2010 at 11:25:41 from (70.252.186.127):
In Reply to: Hydraulic cylinder question posted by J.J. from Afton on April 07, 2010 at 10:57:15:
First off, a single action cylinder will only "extend" with the hydraulics, not "compress" or retract. You can use a double acting cylinder and vent the end you are not pressurizing, but I would recommend you use a filter of some sort if you do that, to keep dust and dirt out of the cylinder. Then you would need to operate the valve in the other direction to allow the fluid to return to the system. Also it will no doubt take a pretty healthy spring to push the fluid back to the tractor system and extend the cylinder.
I take it you want to operate the mechanical plow lift with a cylinder rather than pull the rope, is that correct?
This post was edited by IH fan at 11:27:11 04/07/10.
