Carl Grover said: (quoted from post at 11:46:50 04/07/10) You seem to know what you are talking about, I took the info I found at face value because it made sense, never took into account the particles were too small to matter, I guess it would be fine to use the 30 wt detergent.
If you use an external valve, remember that you can put a filter in the return line. Motor oil is fine and works well, but will entrain air quickly if the reservoir get low and the pump sucks air when the rams are extended. It doesn't bleed out very well. Stuff like Hy-TRAN handles that situation better.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
