Posted by Janicholson on April 07, 2010 at 17:12:49 from (64.61.211.160):
In Reply to: Up date on super c posted by gary sedlacek on April 07, 2010 at 17:05:02:
No compression will sure indicate a problem. A leak down test is more revealing in tha blowing air into the cylinder (at TDC compression) will blow air out of the leak. Intake , exhaust, head gasket, rings, or hole in the piston. (pulling the valve cover off is also easy). Looking at the valve springs and pushrods define proper valve action. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
