Re: 6volt to 12 volt
Posted by teddy52food on April 07, 2010 at 19:47:26 from (209.237.115.177):
In Reply to: 6volt to 12 volt posted by chad from michigan on April 07, 2010 at 13:47:14:
Why not keep it at 6 volts. 12 may spin it so fast that the impulse on the mag won't catch & it will be firing early which may kick against the starter & break the nose off. Also hard on the starter & ring gears. If you keep it in shape with good heavy cables, it will start in weather too cold to be on it.
