Re: Farmall 706 PTO question
Posted by Owen Aaland on April 07, 2010 at 19:50:07 from (207.13.114.72):
In Reply to: Farmall 706 PTO question posted by B.Bob on April 07, 2010 at 19:29:39:
Most likely what happened is the clutch pack slipped and welded itself together. You can verify that by trying to turn the shaft with the engine off. It takes a bit of effort but you should be able to overcome the PTO brakes by using a pipe wrench on the shaft. If it turns the engine your clutch pack is welded together.
