Re: Sudden smoke
Posted by Andrew Z on April 08, 2010 at 06:58:54 from (64.252.148.52):
In Reply to: Sudden smoke posted by reb-in-pa on April 08, 2010 at 04:27:54:
do a compression test and see what you get should be at least 90lbs, 120 would be great
Andrew
