Sounds like a gas problem, or lack there of. First shut the gas off at the sediment bulb housing under the gas tank. Then check the screen where the gas line goes into the carb to make sure it's clean. Next remove the sediment bulb from the housing & the screen up in the housing & clean. With the bulb off careflly turn gas back on & make sure there's a good flow of gas fro the tank. If all those are ok it's most likely in the carb itself. Refer to the tractors operator manual & make sure all the adjustments are set correctly. Carb may be gummed up if the tractor hasn't been run for awhile & may need cleaned or rebuilt
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
