Re: Correct starter for W-9 /I-9?
Posted by Owen Aaland on April 09, 2010 at 15:27:32 from (207.13.114.72):
In Reply to: Correct starter for W-9 /I-9? posted by pfpuim on April 05, 2010 at 08:36:48:
If you are talking about armature end play, that is controlled by a thrust washer on each end. Total end play should be about 1/32 inch or possibly a little less.
The drive end should have three washers on it. The one on the end has a smaller ID and is the thrust washer. The other two, one thick one and one thin one, are stop washers for the drive. There should be about 1/32 inch gap between them and the drive when assembled. With the wrong drive I could see where there would be about 3/8 inch instead.
