Re: bleeding hyd. on 806D
Posted by cmd1042 on April 11, 2010 at 03:13:34 from (71.31.61.149):
In Reply to: bleeding hyd. on 806D posted by Brad in WI on April 10, 2010 at 09:18:14:
stay with the small plug on the MCV. shut tractor off remove plug it is the small one on the rear or the MCV. MCV is located just below the clutch pedal.get on seat start the tractor wait a little bit you will know shortly if it works shut down as soon as it sprays. it will come fast and hard reinstall plug and you should be good to go.
