Re: Super A Plow - help request
Posted by gene bender on April 11, 2010 at 10:48:49 from (207.177.56.155):
In Reply to: Super A Plow - help request posted by Greg-N-CA on April 11, 2010 at 08:27:16:
You need to turn the drawbar forward and let it move up and down hooked to the rocker arm. You need a rockshaft assy between the rear fenders that wil likft and lower the plow into the ground. Beam on the plow will hook to the drawbar. Yours probably isnt long enough. Just use a chain from rear rockshaft to lift and lower the plow. You will have to make a solid bar to raise and lower the drawbar.as thats the way you set plowing depth.
