Re: W400 clutch adjustment
Posted by rustred on April 11, 2010 at 11:41:47 from (72.172.100.113):
In Reply to: W400 clutch adjustment posted by Joe-Illinois on April 11, 2010 at 10:36:06:
free play is 3/4 to 1" between trans. cover and clutch pedal by adjusting clutch rod length.T A should be adjusted as per manual.
