Re: w-4 with knock, need suggestions
Posted by 36F30 on April 11, 2010 at 12:20:08 from (75.253.119.22):
In Reply to: w-4 with knock, need suggestions posted by homebuilt on April 11, 2010 at 12:05:22:
Yep, time to pull the pan and see what you can move. Hows the oil
pressure? Generally bad wrist pins don't bleed off pressure while
the rod bearings will. Knocks from the topside caused by valves
usually only knock a few times before they grenade something.
