Posted by Janicholson on April 11, 2010 at 12:59:41 from (64.61.211.25):
In Reply to: 300U Stuck in Reverse posted by badaugherty on April 11, 2010 at 12:42:18:
Pretty easy fix Take the shifter off of the top of the trans (bolts around the small housing at the shifter). Put it Low TA (pull lever back). Push in the clutch. Use a big screw driver or small pry bar to align the shift rails. The right hand rail will be to the rear, it needs to be moved forward to align the slots. Have the tip of the shifter that fits into the slots made fatter by welding a little metal onto the tip where worn, and using a grinder to make it so it just fits and moves through the pattern. Shift in square movements in the pattern to avoid this in the future. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
