Re: H charging replace cutout with regulator
Posted by Bob M on May 26, 2000 at 10:22:14 from (192.232.120.194):
In Reply to: H charging replace cutout with regulator posted by bunky on May 26, 2000 at 04:11:46:
third party image
I made this diagram for my Super H. Should work for on your H. Only difference is the terminal numbers may be different on your 4-position light switch (mine's got the 3-position switch).
Post A Followup
: Re: Re: H charging replace cutout with regulator
