Re: 1947 Farmall H Carburetor
Posted by CNKS on April 11, 2010 at 17:58:21 from (216.144.104.128):
In Reply to: 1947 Farmall H Carburetor posted by Judie in Ohio on April 11, 2010 at 09:09:26:
Remove the carb, completely disassemble, soak in real carb cleaner overnight, blow out all ports with compressed air, and put an IH kit in it. The kit should include the drip hole parts, but I am not sure, CaseIH can get them. Initial settings are 2.5-3.0 for the main jet and 1-1.5 for the idle mixture. With the engine hot, set the idle speed screw and idle mixture screws so that it idles smoothly. At wide open throttle turn the main jet screw in until the engine stumbles, then out until smooth plus maybe a quarter turn more. Retard the throttle and rapidly advance. If the engine does not accelerate smoothly, repeat the adjustments. That should do it unless your carb is extremely corroded.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
