Re: Farmall 460 hydraulics
Posted by pete 23 on April 11, 2010 at 20:10:38 from (173.87.145.42):
In Reply to: Farmall 460 hydraulics posted by Matt1983 on April 11, 2010 at 19:04:01:
Well, for starters, if your hitch is dropping and correcting itself that means it is leaking. You have a check valve under seat to hold cyl up so either that is leaking or the cyl is. With engine shut off and a load on hitch , remove hose that is not holding load up, if hitch is going down oil will flow out of hose if cyl is problem ,if no oil is coming out of hose and hitch is going down check valve is leaking. After you correct hitch problem then you can see if you still have lifting problems and heating.
