Re: advice for leaking radiator
Posted by Jg20601 on April 11, 2010 at 20:51:17 from (63.28.39.206):
In Reply to: advice for leaking radiator posted by Ross Kaminsky on April 11, 2010 at 11:08:17:
Make sure that it is the radiator. When I was moving snow with my 140 in feb, the lower radiator hose clamp cracked - would get antifreeze getting sucked into the fan and blowing over the engine. Finally found a stant pressure tester for older cars and thought I had a cracked radiator inlet - but found out it was a cracked hose clamp.
