Re: Type of oil for c
Posted by CNKS on April 12, 2010 at 06:53:29 from (216.144.104.128):
In Reply to: Re: Type of oil for c posted by Dale L on April 11, 2010 at 18:24:10:
The leak is either a seal or oring, depending on which pump you have--available anywhere. If the seal or oring has worn a groove in the shaft you need a $25 or so speedy or redi sleeve (trademarks). If an oring you need to have a machine shop enlarge the hole the shaft goes through to accept the sleeve. If a seal you can install it yourself.
