Use a diferent amp gauge on the system. YOur gauge could be either failing, or not dampened properly. If it stops charging, maybe it should be not charging (battery full) Tests: All with fully charged battery Run it at 1/3 throttle (lights off) so the gauge shows charge steady as you have stated. Put an analog (Needle type) meter across the battery. Reading should be 6.8 to 7.3 volts (about) Run at full throttle with lights off. Should read 7.2 to 7. 4 (about) If it stops charging, check the voltage again across the battery. If still at 7.2 to 7.4 all is well, and the regulator is working correctly. (you should not over fill the battery, and it should go back to near zero charge rate. If the needle swings radically as before, and the voltage is good, I would then use a different amp meter to see if it is a defective meter dampening. If the bat volts go back to 6.5 to 6.6 when the needle goes back to near zero, then there is an open in the system. You should be able to find a faulty VR ground, or a bad connection because it is not working. Please let us know your progress. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
