Re: Farmall 460 hydraulics
Posted by Aces on April 12, 2010 at 09:33:10 from (64.5.67.189):
In Reply to: Farmall 460 hydraulics posted by Matt1983 on April 11, 2010 at 19:04:01:
Matt If the hydraulic is getting hot as you say then the unload valve is staying loaded or high pressure. It could have bad oring bad seat or dirt. It is behind the plate with the 4 3/8 cap screws to hold the 2-1/2 x 3" plate. That plate as a big spring behind it, the pressure relief spring. So remove 2 of the screws opposite each other and put 2 longer screws in so the plate does not fly off.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
