Re: Re: Best finish mower setup- 3 hilly acres?
Posted by Jerry on May 26, 2000 at 12:55:59 from (216.64.57.227):
In Reply to: Re: Best finish mower setup- 3 hilly acres? posted by Matt on May 25, 2000 at 21:35:23:
Thanks for the reply. Sounds like you have the same type of grounds as I do. I don't think I could maneuver a gangmower well enough to get around everything that is located just where it shouldn't be.
So the question is what does have just enough plus a little hp to spare and is fairly small (light) so that with turf tires it won't rut up the lawn in the spring when it can get "dampish" but still has to be cut?
Everything is a trade off but I like old tractors and the thought of putting thousands into a new riding mower with a pressed steel frame is not that appealing. Altho in truth I have to admit that a single purpose machine will usually do its job better than a general purpose machine doing the same job. Like you with the Bobcat, I guess.
How fast is that 2nd gear on the cub, you guesstimate?
Thanks for your two cents!
Jerry
Post A Followup
: Re: Re: Re: Best finish mower setup- 3 hilly acres?
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
