Re: 504 hydrolick noise
Posted by HandClucth on April 12, 2010 at 18:49:44 from (98.224.115.127):
In Reply to: 504 hydrolick noise posted by farmer budd on April 12, 2010 at 18:20:01:
The Hydrolick pump is sucking air or the filter is pluged. There is an (o) ring behind the filter on a pipe going to the pump that can go bad and can cause air sucking. Try the filter first.
