Re: Super A Hunts
Posted by gregk on April 12, 2010 at 19:40:14 from (75.105.32.52):
In Reply to: Super A Hunts posted by Phillip Low on April 12, 2010 at 11:41:42:
I had a similar problem with my B. A year later I developed a bad knock in the engine and it ended up that the timing gears were missing teeth because the thrust bearing on the governor had let loose all of the little balls of the ball bearing. One of these fell down into the gear teeth and broke several of them out making the knocking noise. It might be a lot of work but I would check this out if nothing else works.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
