Re: H won't start with spark
Posted by El Toro on April 13, 2010 at 04:21:00 from (74.103.74.58):
In Reply to: H won't start with spark posted by Dan G on April 12, 2010 at 18:36:33:
Hold your hand over the throat of the carburetor and see if there's good suction while someone makes an attempt to start the engine. If there's low suction that's an indication of low intake manifold vacuum. You need good manifold vacuum to suck that fuel into the engine. Pull the sparkplugs and pour oil on top of the pistons then bump the engine over. I would pour more oil on top of the pistons and let it soak over night. Then bump the engine over again and reinstall the plugs and see if the engine will start. Hal
PS: If it starts it will smoke until it burns off that oil.
