Posted by pete 23 on April 13, 2010 at 10:11:44 from (173.87.145.42):
In Reply to: Confirmation posted by Kevin in MI on April 13, 2010 at 07:31:59:
You have to realize that the inside end of the bull pinion shaft is supported by the side gear in the differential. These old diff's get pretty worn and allow that gear to move up and down quite a lot. Grabbing ahold of the end of the bull pinion shaft you may very well be feeling that gear moving up and down. You will have to look closely at the bearing to determine if the play is in the bearing itself or the diff. This is common setup on all these style tractors until later larger models like 706 went to a straddle mounted bull pinion with tapered roller bearings on each side of gear. The 656 used a needle bearing or bushing inside the differential to support that end of shaft and tapered roller bearing on the outer end.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
