Re: What size set screws to attach cultivators on A, Sup...
Posted by NawlensGator on April 13, 2010 at 11:12:30 from (52.129.8.51):
In Reply to: Re: What size set screws to attach cultivators on A, Sup... posted by NawlensGator on April 13, 2010 at 10:57:33:
That bracket described above is called a cultivator clamp, and you can buy them from a IH/case dealer or on ebay.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
