I want to clarify what I mean by the step on the bolt. When you clamp down those bolts you deform the ends and you cannot get them back out of the hole if you need to. The threads are deformed and too large. Therefore, if you put the bolt in a lathe and turn 2 threads or so down to the root diameter, essentially creating a step, you deform the end but don't expand threads (you have clearance now) and you can therefore get the bolt back out of the hole. If you don't have a lathe a grinder can be used in a pinch if you are careful
The jam nut is needed because no matter how hard you clamp those bolts down the vibration and banging will loosen them and you'll have to retighten every round. Learned this the hard way.
A 2" bolt is long enough. Actually about as long as you can use on the hole closest to the block / oil pan.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
