Posted by Bob on April 13, 2010 at 12:03:20 from (69.178.228.68):
In Reply to: Re: Alternator help posted by Zachary Hoyt on April 13, 2010 at 11:40:03:
If you had the engine running when you took those voltage readings the alternator isn't working.
I numbered the terminals for you... #1 gets voltage only when the switch is "ON", and should have an "idiot lamp", diode or resistor in-line to prevent the backfeeding of current OUT that terminal.
#2 is the "voltage sense" terminal and on automotive apps it's connected to a point near the (+) battery cable to sense voltage as close to the battery as possible. For theses simple tractor conversions it's typically just jumpered over to the alternator's large output stud.
It's a 10SI Delco. Simply ask the autoparts folks for an alternator for a 1975 Chevy pickup with 350 engine, NO air conditioning (unless you want a HIGH output unit).
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
