With both valves closed (TDC compression stroke) with the tractor in High gear, and brakes locked. Air pressure (100psi or so) is put in the spark plug hole, and one listens to hear where the air leaks out. Air cleaner, oil fill hole, exhaust, radiator, etc. (yours will be more than likely from the oil fill hole) It won't tell you if it is a cracked piston, hole in piston, or broken ring. It will just confirm the need to pull the head and get a visual of the piston. It has wet sleeves which are easy to remove. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
