It would be helpful if we knew what was in the kit. A picture would be even better.
The IH solution for one remote double acting hydraulic circuit was the Christmas Tree valve. They were installed on SMTAs as well but you don't need it as you already have spool valves.
When the live power option became available, the reservoir was repositioned under the gas tank. On the back (left) side (facing operator) are three ports. Use the bottom 1/2" port to run a pressure line to your valve. Run the return back to the reservoir or the next valve. If I recall correctly, there is a plug on left side of the reservoir for return oil. If not, install a tee at the fill plug.
You will have to hold the liftall lever back while operating the Prince valve. Or you can lock the lever back by rotating the small tang attached to the reservoir.
Not sure why they sent you a plug.
This post was edited by Wardner at 18:31:08 04/13/10.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
