Re: Wiring question
Posted by Janicholson on April 14, 2010 at 13:18:26 from (199.17.6.222):
In Reply to: Wiring question posted by Ray in CT on April 14, 2010 at 13:01:28:
There may be no such thing. A proper 6 volt harness is available from several sources. They are the same as 12volt. The wiring makes no difference between 6 and 12v. If you have an alternator, the wiring for that will be in adition to the wiring supplied for the generator. The 10 gauge wire originally intended for the Bat terminal on the VR can be used for the Alt main output wire, other than that the 6v wires are fine.
Jim
