Re: H still not starting - Day 5!
Posted by M Diesel on April 14, 2010 at 16:15:23 from (12.24.61.12):
In Reply to: H still not starting - Day 5! posted by Dan G on April 14, 2010 at 15:42:24:
I would say that dry plugs says it all. Plugged passages in the carb. Gas evaporates up through the jets, leaving behind residue that eventually plugs them. Especially with 87 octane.
I generally use brake cleaner as a starting aid for gas engines. Not nearly so difficult to use as ether. And yes you can run one with no fuel in the carb. You can run small engines with fumes from a milk jug.
Be very careful dumping raw gas into a machine. It doesn't ignite well, and a slow burn may go to a full pop and blow burning gas out onto you. Know a guy who did it with a JD two banger. Skin grafts.
