Re: H still not starting - Day 5!
Posted by oldiron29 on April 14, 2010 at 16:16:41 from (69.112.212.24):
In Reply to: H still not starting - Day 5! posted by Dan G on April 14, 2010 at 15:42:24:
Dan, with all the cranking you did. If you pull the choke do you get fuel running out of the carb? Never heard you say you had fuel running out or flooded? If you get fuel running out of line at carb connection. you have fuel to carb but not out. I think you are not getting gas through your carb. Needle stuck or jet cloged.
Should also check timming I don't know why you are getting puff or fire out of carb.
Oldiron29
