Re: Farmall 460 hydraulics
Posted by Matt1983 on April 14, 2010 at 17:14:15 from (71.234.106.161):
In Reply to: Farmall 460 hydraulics posted by Matt1983 on April 11, 2010 at 19:04:01:
I took apart both valves. The one under the seat and the one under the dash. Niether of them had rust or any signs of wear. The piston also does not seem to be leaking or bypassing, which was made clear when I reconnected it to the check valve under the seat and relized it was on backwards and would not go up or down and was straining the pump, which I would assume shows that the check valve in the piston is working.... I just find it hard to believe that a bad pump would heat up the oil while working so well when cold but not work at all when hot. I have not run the tractor long enough yet to see if the problem is still occuring after disassembling those parts however I cant imagine it will be any different then before since I didnt really do anything to it. Anyway thanks for the help to all of those who replied. Any more ideas are welcome. Thanks! Matt
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
