Re: H still not starting - Day 5!
Posted by Tom Fleming on April 14, 2010 at 18:15:32 from (72.4.231.242):
In Reply to: H still not starting - Day 5! posted by Dan G on April 14, 2010 at 15:42:24:
I have to ask. the very very first time you tried to start it, did it fire once then begin this behavior?
Might want to pull the distributor, and check the gear on the end. Make sure the gear is intact (ie. no teeth missing) and not spinning on the shaft. also, have you checked to see if the rotor is spinning while cranking, ie. the tab is not broken off inside the rotor.
Based upon your description of the "back fire", you are definately out of time. If what you have stated is accurate, and I have no reason to doubt you, the tractor is firing with the intake valves open (ie. not completely closed).
just a thought............if you already haven't done this.
