Pull all spark plugs and squirt motor oil in each cylinder (3-4 pumps) to assure greater compression. Crank a few revolutions to spread the oil around the cylinder and re-build the sealing ability of the piston rings. The spark leaving the coil to distributor wire (distributor cap end) should be bright blue and snappy jumping at least a 1/4" gap. If you haven't changed the timing since last fall, the spark is strong, and the compression is decent, about all that is left is the fuel supply. Send me an e-mail so I can give you my phone #; maybe I can help sort out the problem for you.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
