You need to do as one poster suggested, make sure your distributor has not sheared a pin or taken some teeth out. You have to establish that you are getting that spark to the cyl at the proper time, pull number one spark plug, put your finger over the hole and crank by hand until you feel compression. Then align the timing mark, will be two close together, five degrees apart, first one is tdc. Now your points should be just opening in their normal direction of rotation of the distributor. Until you establish this you are just guessing. The reason you see spark at the points when cranking with dist cap off is the secondary in coil is building high voltage against an open circuit, therefore the voltage in primary winding builds higher than normal and arcs at the points. There are as many different ways to check for a good spark as there are people doing it. It sounds like you have spark but at wrong time. And yes indeed, it will run by spraying gasoline, or starting fluid or many other flamable fluids into intake even with out a carburetor one it. Keep trying, you will get it but be very careful around the carburetor and using various fluids.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
