There are a couple methods, but one that will work good for you is; remove the spark plugs and put your finger into one of the holes, turn the engine in its normal operating direction until you feel pressure against your finger. Set the valves on that cylinder and do the same for the other three. If you don't get a good seal when you put your finger into the spark plug hole, don't sweat it. As soon as you can hear of feel air escaping, your OK to set the valves.
I don't know what the valve clearance is for that tractor so I can"t help you there.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
