Re: H still not starting - Day 5!
Posted by El Toro on April 15, 2010 at 04:38:02 from (74.103.74.58):
In Reply to: Re: H still not starting - Day 5! posted by Dan G on April 14, 2010 at 20:17:02:
You need to bring that piston near the radiator to TDC on the compression stroke. Once you have No1 piston at TDC on the compression stroke remove the cap and see where your rotor is pointing. You don't need a timing light to get the engine running. When you have No1 piston at TDC on the compression stroke both valves should be closed and your timing marks should be aligned. The rotor should be pointing to your No1 plug wire on the cap, then the next plug wire should go to No3 sparkplug around the cap clockwise, then No4 and then No2. Hal
2-1
4-3
